Libby help
Libby help
I am thinking of starting up drk angels and a double bike librarions look cool. So for their phycic hood they can attempt to nulify spells, so my question is if I took two librarions would I get to attempt to nulify only with one Libby or both?
sewerstalker- Assassin
Re: Libby help
Unfortunately not, at least not as far as I can tell.
The old Psychic hoods don't really say one way or the other, so while you could arguement, there is pretty much a mountain of precedence saying that they shouldn't. Hoods in the new codex's specify you can only use them once, Sisters of battle either get their 5+ nullify or a hood, not both and so forth.
Re: Libby help
The Space Marine codex specifically states that you can only use one. PG 56 under Librarian's Psychic Hood entry: "If there are several Librarians in range, only one can attempt to nullify the psychic power - you must choose which".
Also, the Sisters 5+ save doesn't say it can't be taken with a Psychic Hood, It's the Grey Knights Aegis that makes you choose which to use.
From what I've been able to tell, the only thing (Imperial side) that DOES stack with a psychic hood is the Sisters of battle Shield of Faith.
The benefit to Two librarian hoods is that they could both cover seperate areas of the board, giving your extended coverage with your hood, and giving you a backup hood if one should die.
Personally, I still say Inquisitor FTW, but I'm biased.
Re: Libby help
Thanks guys for your help. Totaly wish I could use both hoods. Haha
